    Default Home Inspection Litigation Consulting
    "Home Inspection lawsuits involving homeowners, home sellers, or real estate professionals
    If you are a homeowner, home seller, real estate professional, or attorney representing any of these individuals and you’re considering a home inspection lawsuit, or have already initiated legal action with regard to a home inspection, contact Kevin for home inspection litigation help. PROSPEX can help you understand and use applicable home inspection standards of practice to your benefit.
    Home Inspection lawsuits involving home inspectors
    If you are a home inspector or an attorney representing a home inspector regarding pending or ongoing home inspection lawsuit, contact Kevin for home inspection litigation help to discuss how PROSPEX can help you understand and use applicable home inspection standards of practice to your benefit to reduce home inspector liability..."
    Home Inspection Litigation|Home Inspection Lawsuits
    Default Re: Home Inspection Litigation Consulting
    Many of us do this. Are you trying to point something out, or just advertise for Kevin O's service?
    Clicking on " contact Kevin for home inspection litigation help " only produces this "404 Error - Not Found" and "The resource you have requested could not be found on the server."
    Great advertising, huh?
    Richard Rushing's Avatar
    Richard Rushing Guest
    JP-- he finally got it right on the last try...
    RR
    "Kevin O'Hornett of PROSPEX has spent the past twenty-two years analyzing and critiquing various home inspection standards of practice."
    Hmm........ perhaps he should have been out doing some home inspections?
