    Ken Milton's Avatar
    Ken Milton Guest
    Default Flue against roof sheathing
    I inspected a house today and this flue from the water heater was against the roof sheathing. I believe it needs a 1" clearance. Any help would be appreciated.
    Default Re: Flue against roof sheathing
    Quote Originally Posted by Ken Milton View Post
    If that's single-wall pipe, which it looks like, it needs six inch clearance.
    Ken Milton's Avatar
    Ken Milton Guest
    Thank you. It is single wall.
    Assuming that's an attic, can't be single wall in any case.
    I see dryer lint there, are you sure it's the water heater flue?
    Good point Dom! I have also seen bathroom and kitchen vents exhaust like that.
    Michael,
    How about in a house that was built before double wall vents were made?
    JF
    Ken Milton's Avatar
    Ken Milton Guest
    Thank you guys for all your advice. It is not dryer lint, it is blown insulation. Yes it is the water heater vent. I put in the report that it might be a single wall and that the clearance were not correct.
