    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Missing tie betweem timber beams
    Is a strap, plate, or tie required at the end bearing and joint between the two beams? The place was built in 2008 and this is under a canopy entry. The column is anchored into a concrete footing. But as you can see they simply toe nailed the two together.
    Default Re: Missing tie betweem timber beams
    No requirement other than if one was specified in the original blueprints. Most likely the house was built without spec for details like that.
    A.D. Miller's Avatar
    A.D. Miller Guest
    A.D,
    Thanks that is a nice link.
