    Stephen G's Avatar
    Stephen G Guest
    Default Basement bathtub
    Friend of mine asked if he could install a low profile p trap for his existing basement bathtub. I asked him what led him to think he doesnt have one now. He says he got a look under the tub and its a straight pipe into the slab cutout and into the gravel. Cant see anything beyond that.
    questions
    1. Is it possible there is a trap down stream, under the gravel, further?
    2. what would happen if he did add a trap ahead of one downstream. I think that you cant/shouldnt have two traps
    3. If it doesnt have a trap why doesnt the basement smell real bad.
    He lives nowhere near me so I cant just walk over and look, and he appears to be camerea challenged, his pics have been useless.
    Steve
    Default Re: Basement bathtub
    Quote Originally Posted by Stephen G View Post
    Yes, there probably is a trap down there.
    Not allowed to double trap, could lead to backups. Not good.
    Because is has a trap ... ...
    ... unless the waste line is higher than the tub drain, in which case that may go down to a sump pump which lifts (pumps) the water up to the higher waste line.
    Stephen G's Avatar
    Stephen G Guest
    Thanx Jerry, I am going to suggest he gets a scope and find the trap.
    Nov 2007
    Chicago
    How old is the home? and the install of this tub? If there is a trap further down the line it will have to be a drum trap. P-traps have to be directly below the outlet of the tub waste and overflow.
    HEre are a couple drawings show what I mean.
    Stephen G's Avatar
    Stephen G Guest
    Home is 10 years old. HO is going to school in TO, so getting answers from him are sporadic.
    Thanx for the pics Ron
    If it goes into a gravel block-out, why not just dig down with a gardeners spade?
    That was my thought too.
    Ron, I'm thinking that "down stream, under the gravel, further?" means: down under the gravel a bit further down. Not "down stream in some other location.
    I could be wrong, I have been wrong before ... many times.
    Stephen G's Avatar
    Stephen G Guest
    He placed a snake into it and it jammed at about three feet. I put another call to him to remind me how we started this exercise in plumbing.
    I am not a plumber and have never heard of a trap burried under the gravel, what a pain in the asp to install...
    I have pressed him for photos...
