Page 2 of 2 FirstFirst 12
Results 66 to 71 of 71
  1. #66
    Sep 2009
    Dallas, TX
    Default Re: Door Between Garage and House
    That door "must" be fire rated? You sure? Has Texas adopted something different than the IRC?
    1 hour burn rate. Sometime.....sooooooooometimes, I don't quote the IRC directly.
  2. #67
    Nampa, Idaho
    Those types of doors typically have a cheap plastic frame that supports and holds the glass in place. I've seen many of them deteriorated from UV exposure. Most likely the plastic frame would quickly melt allowing the glass to fall out.
  3. #68
    Quote Originally Posted by Robert Slight View Post
    "1 hour burn rate."? Where did you get that from?
    Aug 2011
    Quote Originally Posted by Dwayne Smith View Post
    Issues in your garage door can happen anytime. If you need immediate assistance at any time of the day, highly trained servicemen are equipped to deliver prompt services to you.
    Dwayne, can you be here at 9:00?
  5. #70
    Sep 2009
    Dallas, TX
    You're right, 20 minute burn rate...thanks CodeMan.
    I thought it was SPAM. It looked like someone may have hijacked his account. Wooops....not meant to offend.
  6. #71
    Robert,
    The proper way to refer to that is a 20 minute rated door.
    The 20 minutes isn't the burn rate, rather it is the minimum protection time under the test conditions.
    Also, the 20 minute rated door is not a requirement, it is just one of the options for that door.
