    Ron Bishop's Avatar
    Ron Bishop Guest
    Default Gas control valve in firebox
    It seems to me that this gas control is awfully close to flame...any thoughts?
    Default Re: Gas control valve in firebox
    As far as I know it's ok for gas log, not wood burning.
    Ron Bishop's Avatar
    Ron Bishop Guest
    thank you kindly
    Eric is correct. That is 'part of' a listed and labeled gas log set. You can see the insulation on the floor, which is intended to look like 'burning embers' when the gas log set is on and burning.
    Exclamation Re: Gas control valve in firebox
    Valve is fine if the entire set is listed to ANSI Z21.60. However, that gas knockout to the right is not properly sealed.
    Ron Bishop's Avatar
    Ron Bishop Guest
    good point
    Quote Originally Posted by Ron Bishop View Post
    good point
    Boom, Boom, Baby!
    Didn't see that.
    However, is "properly sealed" the right phrase? That implies it is sealed.
