Results 1 to 12 of 12
Thread: wire big enough?
05-11-2007, 01:38 PM #1
wire big enough?
Take your best guess - 15 amp breaker with #4 copper.
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
05-11-2007, 03:25 PM #2
Re: wire big enough?
Best guess... o.k. (this is a W.A.G)
The stove was previously an electric unit but was changed out to a gas unit.
What'd I win???
Rich
05-11-2007, 03:31 PM #3
Close, but no cigar, which is too much of a hint, I guess (not the cigar).
05-11-2007, 03:38 PM #4
05-11-2007, 04:30 PM #5
Thanks Rich, as usual, got me laughing after a long day.
05-11-2007, 07:21 PM #6
Okay. Used to have an electric range and oven. Converted to gas. One leg of the 220V is folded up out of the way, but still in the panel. The other end of the #4 is pigtailed to a piece of #14. A new 110V receptacle is laying on the floor behind the gas range where an extension cord runs up to the new light over the gas range. A clip on switch is snapped into the extension cord.
What did Rich win?
- Paul Fix
05-11-2007, 07:23 PM #7
A heat pump was replaced with a gas furnace...
05-12-2007, 02:52 AM #8
bingo
05-12-2007, 11:46 AM #9
Was the breaker rated for a wire that big?
looks like it is only rated for 14-10 AWG
05-12-2007, 01:03 PM #10
05-12-2007, 02:21 PM #11
Sorry, Rich. I tried to win you something.
I be John and James are cousins or something.
- Paul Fix
05-12-2007, 02:46 PM #12
I saw something similar a few months ago. They was a 150 breaker in the service panel that used to feed a 240 volt electric furnace in the crawlspace. They had taken one wire off of the 150 breaker and made it a neutral so they could have 110 volts for the newly installed gas furnace. They installed a 20 amp single pole breaker for the gas furnace in the old electric furnace panel. I wrote up what I saw but it looked ok to me.
