    Default Strike Plate Problem
    This strike plate appeared to be slightly misaligned. For that matter, the door to go along with it seemed to be missing.
    Suggestions?
    Default Re: Strike Plate Problem
    Well ... Duh! They forgot to mortise the strike plate into the jamb!
    No Friggin' Wonder it's misaligned.
    So ... was there a door somewhere in the house with a plumbing fitting where the strike plate is supposed to be?
    Hey! We just got 'em mixed up! No biggie!
    So ... was there a door somewhere in the house ....
    John,
    Fortunately, you did not open that camouflaged 'invisible' door, that is the door to ... The Twilight Zone.
    Eric Shuman's Avatar
    Eric Shuman Guest
    My guess is that an over zealous plumber cut the door out with his saws-all to make room for the drain pipe.
    Eric
    Look like something from one of those episodes from the "Trading Spaces" show on HGTV.
    Jeff Remas's Avatar
    Jeff Remas Guest
    It will continue to be misaligned until they put the other screw in it.
