Results 1 to 12 of 12
Thread: Unknown piping.
    Eric Shuman's Avatar
    Eric Shuman Guest
    Default Unknown piping.
    Ran across this yesterday. Not sure what it is for. On the outside there was this configuration (photo1) and on the inside a closed loop of pvc pipe (photo 2).
    Any ideas? I thought maybe a water softener hook up that is not used but I haven't seen this set-up before.
    Any ideas?
    Thanks,
    Eric
    Corpus Christi, TX
    Default Re: Unknown piping.
    Is the gray line teed into the loop or is the sock just holding the open line against the loop?
    - Paul Fix
    Eric Shuman Guest
    The sock is just holding the gray line crimped over and against the loop.
    Thanks,
    Eric
    There used to be filtration system/treatment system equipment in that room?
    Eric Shuman Guest
    That is what I was leaning towards.
    Eric
    Corpus Christi, TX
    I think you are dead on.
    - Paul Fix
    Georgetown, KY
    No, you're dead off.
    It is a heat loop (using the ground and home heat) to keep the faucet from freezing.
    OK, OK. It's just a wild thought that popped into my head when I saw the pictures.
    Colorado Springs, CO
    Some sort of backflow preventer?
    Bruce Breedlove
    www.avaloninspection.com
    Quote Originally Posted by Erby Crofutt View Post
    Not that wild.
    That was my first thought too, some type of geo thermal heat loop, then I realized there were too many things 'not right' for that to be the case.
    I had to look again and then came up with the filtration/treatment probability.
    Corpus Christi, TX
    Eric,
    Let us know.
    - Paul Fix
    Eric Shuman Guest
    O.K.
    I inspected a one year old house today and found a very similar set-up attached to a water softening system in the garage. Photos 1-2. So back to "Dead on" I guess.
    I have seen plenty of softener installs but not with this particular set-up.
    This one today even had the hose bib and all just like the other.
    Todays inspection also had this nice support sytem for a 65 gallon water heater and furnace/evaporator coil combo in a second floor closet! See photo 3. Needless to say, the deck they were resting on was sagging a bit.
    Eric
    Corpus Christi, TX
    Thanks for following up.
    - Paul Fix
