Results 1 to 13 of 13
Thread: Tank Cover
    Kirk Hersee's Avatar
    Kirk Hersee Guest
    Default Tank Cover
    Can anyone tell what this cover is for; septic?
    Default Re: Tank Cover
    Quote Originally Posted by Kirk Hersee View Post
    Either that or a well.
    Hopefully not both.
    Kirk,
    Only one? Generally, there are two covers. One for each tank chamber. At least that is typical around here.
    Up here thats a well casing. Very common.
    Kalamazoo, MI
    Look's like a septic riser/cleanout...did you pull the cover?
    RJDalga
    http://homeanalysts.com
    Kalamazoo, MI
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    a) Septic cover - sometimes only one cover on old tanks
    b) Well cover - possibly well with submersible pump
    c) Al Capones hideout
    Quote Originally Posted by Jim Zborowski View Post
    Hope This Guy Doesn't Show Up!
    Timothy M. Barr's Avatar
    Timothy M. Barr Guest
    One of two things . Well pump entrance, or septic tank cover I have seen both
    Kirk Hersee Guest
    Kirk,
    There is another cover that is flush with the ground about 50 feet or so away. It looks similar to this one, but like I said, the cover itself doesn't rise out of the ground. There is also a sewer cover in the yard (it is labeled). I think the house was built in the mid 40's. I don't know if that is pertinent info or not. Most everyone around here is connected to town sewerage. Anyway, thanks for the possibilities.
    Rboert, I did not pull the cover. Thankfully, I am not supposed to
    Dave Gilstrap's Avatar
    Dave Gilstrap Guest
    I have seen them around here in the Foothills for a small septic holding tank with a sump pump that pumps the sewage uphill to the municipal sewer lines
    Noreen Loos's Avatar
    Noreen Loos Guest
    Hi
    I believe that this is a well cover - after I read the rest of your info. The other cover, level to the ground is probably for a "dry well" (grey water) & would require regular cleaning to remove the soap layer. The lid labeled Septic is for the sludge type of septic only. It used to be quite common for "dry wells" to be used for grey water.
    RANDY NICHOLAS's Avatar
    RANDY NICHOLAS Guest
    If it is a well and there might be septic tank 50 feet from this cover.
    Tell the buyer "DON'T DRINK THE WATER".
    A water well should be at least 100 feet from a septic tank.
    Randy
