Thread: Water heater flue connection
12-14-2008, 09:23 AM #1
I have never seen this type of hook up before. The water heater flue is connected to a large flue going into chimney coming from a wood stove burner in the basement. If I read the code check correctly it states water heater flue pipe cannot be connected to masonry chimney through a solid wood burning flue fireplace/heater as shown in this picture I took. Is this correct?
12-14-2008, 10:35 AM #2
Re: Water heater flue connection
can't mix solid fuel and gas ,,you are corect
12-14-2008, 12:01 PM #3
Thanks for the reply Richard.
