    John Stephenson's Avatar
    John Stephenson Guest
    Default Loud gurlging noises - sink/tub drainage
    Default Re: Loud gurlging noises - sink/tub drainage
    I think gurgling is a sign of air being sucked into the drain which is a good thing. A drain that sits there and does not gurgle is stopped up.
    When I hear gurgling, I think improper venting and that the weir is being sucked out of the trap. I recommend that a plumbing contractor should confirm venting or make the necessary corrections/repairs.
    Colorado Springs, CO
    That's an indication of inadequate venting. That's not a good thing.
    Bruce Breedlove
    www.avaloninspection.com
    Tim Moreira's Avatar
    Tim Moreira Guest
    Ditto Gunnar and Bruce.
    Venting issue, call the plumber. A properly venting system should be gurgle-free.
