    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Cocaine on my breakers ?
    Ever see this on breakers before? looks like Cocaine. very fine powder.
    Old wires i could not find the numbers. 20amp breaker do these wires look like they are over amp.
    any ideas.
    Best
    Ron
    Richard Pultar's Avatar
    Richard Pultar Guest
    Default Re: Cocaine on my breakers ?
    Spackle dust ,,construction debris from when work was done with the cover off
    Those drug dealers are getting smart on hiding that cocaine. NO drug enforcement agent would think to inspect the breakers. Next thing you know, they'll be hiding it in T&P drain lines. Addicts will be walking in between the houses and snorting on the drain lines for that high.
    rick
    There's even some stuck to the metal protective cover in the photo, and laying on the 'edge' of the metal (top edge of the bottom 'finger' of metal sticking out over the breaker terminal).
    Jennifer Streyckmans's Avatar
    Jennifer Streyckmans Guest
    Well they say people on cocaine are 'wired'. Just not quite what I was imagining.
    Gerry Martin's Avatar
    Gerry Martin Guest
    Looks like oxidation or other chemical reaction. Is this by any chance at a swimming pool? This is often observed in pump room equipment due to exposure to sodium hypochlorite used to disinfect pool water.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Quote Originally Posted by Gerry Martin View Post
    Just an old home. no pool...
    I like the skull...
    Best
    Ron
