Thread: New Member
01-13-2009, 08:25 AM #1
New Member
Hello, from Guin, AL. I'll start out with a question. New construction home, toilet bowl is loosing water level after flushing and refilling, the water in the bowl will drop 1/4". over a short time period. Home has three toilets and two do this and one does not?
01-13-2009, 09:05 AM #2
Re: New Member
Probably nothing to do with the toilets, you've got a venting problem.
01-13-2009, 09:42 AM #3
Re: New Member
Thank you I will check all VTR's
01-13-2009, 09:45 AM #4
Re: New Member
You say it drops 1/4" over time, does it drop another 1/4" over more time, or just that initial drop?
01-13-2009, 10:00 AM #5
Re: New Member
Just the initial 1/4"
01-13-2009, 10:43 AM #6
Re: New Member
Not sure what the cause would be, but I doubt it is venting then.
'How long' is the time duration that it takes to drop that 1/4"?
Seconds, minutes, hours, days?
01-13-2009, 10:52 AM #7
Re: New Member
I will have to get back with the homeowner then get back to you.
01-13-2009, 11:45 AM #8
Re: New Member
A 1/4 inch
How do you know the bowl water drops a quarter inch anyway. Not doubting you. Just kind of curious. I do not measure water in a toilet bowl. Never have. I flush it. It fills up and stops running. All done. I will flush it the second time round. But measure it. Nah.
As far as any other reason beside venting and a slight draw to the bowl when other items are running in the home there could be no other reason. The toilet is nothing but a trap. If you have pour venting and another bowl is flushed it may have just enough draw on it to pull a slight amount of water down the drain. Unles you have a dog or sorry home owner taking a drink from the bowl now and then.
All sounds kinda toilet bowl fishy to me.
