Results 1 to 4 of 4
Thread: Dishwasher
    David Banks's Avatar
    David Banks Guest
    Default Dishwasher
    Homeowner special. Dishwasher away from sink so the hooked up feed and drain directly through floor into basement.
    Any good writeup suggestions. Is there a siphon issue with no high loop?
    Feed line has no shutoff and dubious connection.
    Default Re: Dishwasher
    David,
    If memory serves, no p-trap allowed below floor level (except tub/shower). I think you mentioned no airgap.
    No vent - that's a big problem.
    No air gap, either into a disposal, air gap, or into a tailpiece fitting, all of which allows for an atmospheric break between the water being pumped out and the drain gravity draining away.
    There is a potential for cross connection.
    Accessibility of the trap could be a problem.
    There is a minimum/maximum fall distance to the trap, but everything is screwed up, so that cannot even be measured.
    Those should serve as good starting points.
    David Banks Guest
    Thanks Jerry that helps a lot. Plumbing not one of my strong points.
