    Kevin Teitel's Avatar
    Kevin Teitel Guest
    Default AFCI's in condos
    Are AFCI's required in condo bedrooms? (2003 ICC codes) Since condos do not fall under the IRC I didn't have a quick answer.
    Kevin Teitel
    House-Pro Inspections
    Default Re: AFCI's in condos
    They are under the NEC and the NEC requires them in ALL bedrooms in dwelling units ... and, while the common condo structure is not 'a dwelling unit structure' each condo itself is 'a dwelling unit'.
    The answer is Yes, AFCIs are required in condos just like in regular houses.
    Kevin Teitel Guest
    Thanks.
    Kevin Teitel
    Kevin Teitel Guest
    Follow up question: what if the unit is an efficiency? There is no "bedroom" per say. Does the entire unit have to be AFCI protected?
    Kevin Teitel
    Quote Originally Posted by Kevin Teitel View Post
    Kevin Teitel
    Very interesting question.
    I would say 'all except the kitchen and bathroom ones'.
