Results 1 to 3 of 3
    Oct 2008
    Tulsa, OK
    Default Another mobile home feeder
    I recently inspected a MH feeder. The HO used type TC cable rated for direct burial. It is #4 4 wire copper with a bare equipment ground under the outer covering. The service is 100 amps. Is this a code compliant installation??
    Fred Warner's Avatar
    Fred Warner Guest
    Default Re: Another mobile home feeder
    550.33 ('05) requires 4 insulated conductors or a listed cord. Is the TC tray cable? or is it listed for mobile home assembly?
    Oct 2008
    Tulsa, OK
    Fred- this is TC cable listed for direct burial all the way from the pedistal to the MH service equipment.
