    Richard Thacker's Avatar
    Richard Thacker Guest
    Default Museum Quality "The Cats Meow"
    I posted this earlier on another thread so others could marvel at its museum quality state. I now unleash the hounds to tear it up.
    I know some of you have probably called your therapists because you were afraid to say anything. It is on....Have at it boys!
    **WARNING**
    Attempting to otherwise marvel at its simplicity and elegance. You will be proving to the rest of us, once and for all, with your technical BS, unfounded safety concerns or quotes of some antiquated useless code... that you are indeed a BooB. You must look at this as if it were a piece of art... perhaps a cave painting and live vicariously through the eyes of the pioneer that had to forge his way into a damnable modern age.
    I have come across over a dozen 110volt systems, but this is a winner. For you purists out there, it can't get any better.
    A little background: 2700 sqft victorian home; knob and tube (some buried in the attic insulation); enough blown fuses lying around to fill a 5 gallon bucket; New 2 year old overhead service connection from the pole to the main fuse block (hehe); 7 bedroom multi family unit.
    God Bless America!
    Home Rite Home Inspector, York, Pa - Real Estate Inspection in PA and Maryland
    AllPro - PA and MD Home Inspection and Radon Test - MD Licensed Home Inspector
    Ridgewood, NJ
    Default Re: Museum Quality "The Cats Meow"
    Since the main fuses are green, isn't it a 30 amp service?
    Bill Thacker's Avatar
    Bill Thacker Guest
    Looks to be overfused.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Quote Originally Posted by Richard Thacker View Post
    Richard: Obviously they have different codes there that allow a service replacement without a corresponding equipment upgrade. I might not even inspect something like this; just get back in my van and wave goodbye. . . I'd feel much better with that bucket full of fuses in my rear view mirror . . .
    . . bucket full of fuses . . .
    That was Before Someone Thought of the Pennies in their Pocket.
    Problem Solved.
    No problem.... as the seller's agent will tell you, it's "grandfathered in"
    Michael Mills's Avatar
    Michael Mills Guest
    Am I correct in assuming that this entire affair (main cutout, meter,load cutouts) is located in the attic?? That must be a real thrill for the meter reader, or anyone who has to change the pennies behind the fuses ...
    Mike
    This is a picture of my muesum piece I found a few years back.
