Results 1 to 2 of 2
    Kevin Teitel's Avatar
    Kevin Teitel Guest
    Default Fire sprinkler system
    Can the main water valve be before the branch for the sprinklers? I thought the fire sprinklers had to branch before the valve to prevent the occupant from disabling the system.
    Kevin Teitel
    House-Pro Inspections
    Jeff Remas's Avatar
    Jeff Remas Guest
    Default Re: Fire sprinkler system
    yes and normally with a tamper valve that alarms when it is closed. Most are chained open with break away locks too.
