    Zeeland Michigan
    Default Proper connection
    Good Evening All.
    During an inspection yesterday I found a plastic condensate drain line from an electric pump caulked into a hole drilled into the top a 4" PVC drain pipe.
    Is this considered a proper connection. I wrote it up and am being questioned about the reference by another inspector.
    Does anyone know the reference for or against this.
    No photos.
    Thanks in advance!
    If a man empties his purse into his head no one can take it away from him. An investment in knowledge always pays the best interest
    Benjamin Franklin
    Atlanta, Georgia
    Default Re: Proper connection
    Caulk is not an approved method to join plumbing anywhere, anytime, for any purpose.
    Push back on the other person and ask them to show you where in the code that caulk is an approved method to join pipes.
    Quote Originally Posted by Rick Vernon View Post
    Good Evening All. During an inspection yesterday I found a plastic condensate drain line from an electric pump caulked into a hole drilled into the top a 4" PVC drain pipe. Is this considered a proper connection. I wrote it up and am being questioned about the reference by another inspector. Does anyone know the reference for or against this. No photos. Thanks in advance!
    2003 IRC
    P3003.2 Prohibited Joints. Running threads and bands shall not be used in the drainage system. Drainage and vent piping shall not be drilled, tapped, burned or welded.
    Rick,
    That is also an indirect connection and thus requires an air gap ... a 1" minimum air gap and could need to be larger depending on the size of the plastic tube and how far from the wall it is.
    A 1" air gap is the smallest required for about anything, basically remember a minimum of 2 x the diameter of the discharge opening and maybe more if close to a wall.
    A 1/2" or smaller opening requires a 1" air gap.
    A 3/4" or smaller (down to the above 1/2") requires a 1-1/2" air gap.
    Zeeland Michigan
    Thumbs up Re: Proper connection
    Thank you all for the quick responses and opportunity to learn!
    Benjamin Franklin
