    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default plastic wrapped attic insulation
    have you ever seen this before. I am not sure if this is packaging or if it was designed this way?
    Thanks!
    Default Re: plastic wrapped attic insulation
    There was another thread here recently on that stuff and if I recall correctly that is the way it is allowed to be installed in some instances.
    I've tried searching for it on Google but did not find it, was there a brand name on the bags?
    i could not find anything
    I think Miraflex is the product you are talking about which appears to be discontinued.
    Question: Do you still make insulation covered with plastic? Margie writes from Riverside, New Jersey: "Do you still make the insulation pieces that were 16 in by 24 in and covered by plastic so they were mold resistant? If so, who sells them? If not, is there any thing comparable?"Answer: This sounds like a description of MiraFlex multi-project insulation which was discontinued several years ago. Owens Corning no longer makes fully encapsulated insulation products. A product to consider is Owens Corning PINKPLUS® insulation available at Lowe's. It is not fully encapsulated but it is faced on one side and covered with fabric on the back side.
    Thanks Again!
