    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Water softener discharge into dirt crawlspace
    Does anyone know what the rules are concerning the discharge of water from water softeners directly onto a dirt crawlspace floor? Is it allowed? Thanks for the help.
    Ryan
    Default Re: Water softener discharge into dirt crawlspace
    Quote Originally Posted by Ryan Stouffer View Post
    Ryan
    Nope, not a good idea. If allowed by the municipality it needs to properly discharge into the homes waste line.
    To my knowledge *NO* water is allowed to be discharged into the crawlspace area.
    In fact, that probably is required to discharge into a drain.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Water Softener System Requirements
    http://www.purewater4u.com/images/hy...riesmanual.pdf
    NOTE: Page ten of the one above shows a saddle connection for the drain!
    http://www.ecodyne.org/ws/WHES40.pdf - Page 9
