Results 1 to 13 of 13
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Drain and vent installation
    This is the first time I have seen something like this. It appears the drain line is on the right and the vent on the left. On the back of this wall is another sink with an air intake valve. I think the vent on the sink connects to the intake valve on the opposing wall. Is this acceptable?
    Thx
    Mat
    Default Re: Drain and vent installation
    Forget the photos, it's late
    Is this acceptable?
    Mat,
    At least not as shown in your photos.
    Maybe in some other arrangement, but with that sanitary tee going down, water is going to go down there with it and not just down to the trap.
    That thing is just all wrong.
    state of jefferson
    a true git er done,hack job at best. refer to a plumbing contractor for repairs.
    R. A. Wilkins's Avatar
    R. A. Wilkins Guest
    Mat,
    That drain piping is totally wrong. First off, ABS and PVC pipe cannot be glued together, even if the 'rain or shine' (blue) glue is used, lol. This looks like a feeble attempt to create an 'indirect' drain. If there is a drain on the other side of the wall with an approved vent, these sinks could be plumbed in using a 'cross' fitting and a single vent. Of course 2 approved 'p-traps' would have to be used, (one at each sink tailpiece).
    The plumber's response was the drain on the left of the photo is used to prime a trap in the laundry room and the sink drain is vented through the roof. No rebuttal for the ABS and PVC glued together.
    The 'plumber' said that? not an acceptable response.
    Double trap as now described
    Incorrect trap priming with unsanitary method
    S traps
    Upside down use of a fitting
    Vent fittings where sanitary fittings should be used.
    No cleanout
    Intermediate reduction in trade size
    Too much wrong especially with the introduction of a washing machine somewhere.
    Network with a different plumber.
    Take a look at this.
    Mat,
    That is showing a typical floor drain trap primer installed off the tailpiece.
    That is completely different than the installation shown in those photos above.
    Those trap primer adapter tailpieces have about a 1/2" to 3/4" tap coming off them and are made for that purpose.
    His set up is just plain screwy.
    No problem.
    The food goes down the sink drain and into the washing machine trap and blocks it up nicely. Then of course when the washer trap is dry then the washer connection will have the sink to vent thru. Then you have the sink for the washer to back up into so it does not overflow onto the floor in the laundry room. Like I said, no problem
    state of jefferson
    agree with ted. afterall an inspector showed him how to do it and said it was o.k. hope nobody tells this clown it's o.k. to eat glass!
    Nov 2007
    Chicago
    You should submit them photos to the "Pig slop" thread here The 2009 pig slop contest begins - Terry Love's Plumbing & Remodel DIY forum along with the pdf
