    John Allingham's Avatar
    John Allingham Guest
    Smile Did We Beat You This Time?
    Normally the Ontario Electrical Code lags the US code. Here's a change coming with our new revision effective May 4. Did we beat you this time?
    "Rule 26-712(g) will require all receptacles in dwellings to be tamper-resistant and marked as such. Tamper-resistant receptacles are designed to protect children from injuries when they try to insert keys and other conductive objects into a receptacle".
    Default Re: Did We Beat You This Time?
    Quote Originally Posted by John Allingham View Post
    John,
    That requirement is in the 2008 NEC.
    Shucks.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Shucks.
    John: Not to worry, the 2008 NEC has not been widely adopted.
    Aaron,
    While not widely adopted across the US, I am sure its adoption covers a greater area than "the Ontario Electrical Code" covers (presuming it only covers Ontario).
    A.D. Miller Guest
    Aaron,
    JP: So then, you mean to imply that Florida has not yet adopted the OEC?
