    John Allingham's Avatar
    John Allingham Guest
    Smile Did We Beat You This Time?
    Normally the Ontario Electrical Code lags the US code. Here's a change coming with our new revision effective May 4. Did we beat you this time?
    "Rule 26-712(g) will require all receptacles in dwellings to be tamper-resistant and marked as such. Tamper-resistant receptacles are designed to protect children from injuries when they try to insert keys and other conductive objects into a receptacle".
    Default Re: Did We Beat You This Time?
    Quote Originally Posted by John Allingham View Post
    John,
    That requirement is in the 2008 NEC.
    Shucks.
    Shucks.
    John: Not to worry, the 2008 NEC has not been widely adopted.
    Aaron,
    While not widely adopted across the US, I am sure its adoption covers a greater area than "the Ontario Electrical Code" covers (presuming it only covers Ontario).
    Aaron,
    JP: So then, you mean to imply that Florida has not yet adopted the OEC?
