Thread: another first
    Default another first
    Never seen these useless things either! "Ductless" exhaust fans in the bathrooms.
    Default Re: another first
    You haven't? Used to install them in condos in Miami-Dade all the time, wrote an exception in the code to allow for them as they were listed and labeled and had that charcoal filter doo-dad.
    Then someone got wise and realized that, even though they are called "fart fans" (that was the reason for the charcoal filter - odor control) they really were supposed to be for exhausting the excess humidity *not* odor control, and that those little old charcoal filters did nothing for excess humidity.
    After a few code cycles that exception disappeared.
    In the meantime, though, thousands and thousands were installed in condos.
    I have one in my bathroom. They are useless. One thing with mine is you can put a carbon filter in it. I guess we know what that is for cause it does nothing else.
    ...One thing with mine is you can put a carbon filter in it....
    Yep. That's what's in my left hand in the photo.
    Didn't even realize what you were holding. Mine is a little different
    John said his was "useless" ... your is different than that?
    Mine is less than useless. Put a piece of paper against it and it won't hold it up.
