Results 1 to 3 of 3
Thread: toasted GFCI
    Default toasted GFCI
    If the power company hadn't cut the SEC I would have had the pleasure of testing this fine device.
    Brent Simmerman's Avatar
    Brent Simmerman Guest
    Default Re: toasted GFCI
    I think I would just recommend replacement and save myself the shock!
    Quote Originally Posted by Brent Simmerman View Post
    Replacement!? Without testing it to see if it works?!
    Just kidding.
    True, there's no point in testing its function as a GFCI, but there might be a point in testing the circuit it's on, for grounding, for instance, or voltage drop. Or ... voltage. Here's a pic of the service:
