Thread: Drip edge
04-06-2009, 03:38 AM #1
Drip edge
How would you write this up. I think the roofer thought that a fascia was to be installed on this open rafter end designed house. The shingles are drooping in areas.
Wayne
04-06-2009, 05:31 AM #2
Re: Drip edge
I would just tell them that they used the wrong flashing, but that flashing is not required at that location anyway's (some may disagree). Also, once they install a proper gutter system, it may help lift the shingles slightly.
Overall, I doubt that this installation will cause any problems, and it is better than inadequate overlap.
04-06-2009, 05:46 AM #3
Re: Drip edge
The flashing is the right one, but the installation does not allow the bottom edge to rest on anything allowing shingle droop.
04-06-2009, 06:29 AM #4
04-06-2009, 06:40 AM #5
Re: Drip edge
Yes, Thats what I recommended. Thanks Ted.
04-06-2009, 09:25 AM #6
Re: Drip edge
That will not even take a "high wind" to do damage and peel the roof shingles back, that only needs one "low blow" for that to happen.
Ted is correct, just state it is a very incorrect installation.
Wayne,
Question for you: What is the required ... yes, required ... nailing for roof sheathing in your area?
I ask because most areas require that edge to be nailed at a spacing which would not allow "open rafter" designs.
04-06-2009, 10:36 AM #7
04-06-2009, 01:13 PM #8
Re: Drip edge
Thanks AD,
I can use those in the future. He's got bigger fish to fry at the moment with what was in the rest of the report.
04-06-2009, 05:58 PM #9
Re: Drip edge
That's what I get for posting that early in the morning.....
04-06-2009, 06:38 PM #10
Re: Drip edge
It's noy you Brandon, It's the DONKEY!
