Results 1 to 3 of 3
    imported_John Smith's Avatar
    imported_John Smith Guest
    Default Oh No! Another TPR Question
    TPR Valve and discharge pipe at about 45deg off set from plumb (plumb being vertical). All literature I have ever saw shows the TPR installed so the discharge is vertical, however after going vertical (down) I have seen many cases of 90's and pipe running horizontal and then outside or to another location.
    Hey at least its going down, but it doesn't seem quite right for the TPR to angled 45 degrees?
    Any referencing code or something I can use?
    Default Re: Oh No! Another TPR Question
    As long as it slope down the entire distance to its termination, is not trapped, and the end is within 6" but not less than 6" of the air gap receptor or floor drain, etc., then it will be acceptable.
    May 2007
    Tyler, TX
    P2803.6.1
    "flow by gravity"
    plus all of the other stuff Jerry P. said
    oh, and no "tee fittings"
    Bruce Thompson, Lic. #9199
    www.TylerHomeInspector.com
