    James Savage's Avatar
    James Savage Guest
    Default Bored holes for "home runs"
    I understand the following code for boring holes thru floor joists:
    "The diameter of holes bored or cut into members shall not exceed
    one-third the depth of the member. Holes shall not be closer than 2
    inches to the top or bottom of the member, or to any other hole located
    in the member. Where the member is also notched, the hole shall not be
    closer than 2 inches to the notch."
    My question is how many 3/4"or 1" bored holes, for home runs, can you have in the outer 1/3 of a 2x10 joist? I have seen some floor joists that look like swiss cheese.
    Default Re: Bored holes for "home runs"
    (red text is mine)
    Quote Originally Posted by James Savage View Post
    Now does that mean you could bore it full of holes spaced 2" edge-of-hole-to-edge-of-hole? Well ... that *IS* what it says.
    (red text is mine)
    Yeah the engineers have it there. Personally I hate the idea that you can drill , as was said, these joists to swiss cheese and I only have to question......Huh. I guess they must know what they are doing.
    Mar 2009
    Colorado Front Range
    I've seen a number of joist drilling guides over the years and most all of them agree on a couple of things, different info on others.
    Always agree
    No hole edge within 2" of the top/bottom edge of the joist.
    Hole diameter not more than 1/3 of the ACTUAL depth.
    No notches in middle third of joist
    Sometimes agree
    Holes of the same diameter must be 3 hole diameters apart (ie 1 inch holes are 3 inches apart between edges) Holes of different sizes are 3 diameters of the largest hole apart
    Hole centers must be joist depth apart
    Hole edges and notches must be 2" apart
    No holes in middle third of joist (California Bldg Code)
    Notches not more than 1/3 joist depth long
    Notches not more than 1/6 joist depth deep
    Some local rules help limit the swiss cheese look. See what your local rules are
