    David J. Edens's Avatar
    David J. Edens Guest
    Default Vinyl siding under pavement
    If vinyl siding to a slab attached garage is under pavement grading and the pavement is adjacent to the siding as well, does this pose a serious issue for moisture intrusion? Gutter and eaves are provided as well as a minor slope away from the garage siding that is submerged under the pavement.
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Vinyl siding under pavement
    Quote Originally Posted by David J. Edens View Post
    DE: Yes. Serious problem.
    David,
    As Aaron said, serious problems, one of which is it makes a great super highway for termites that you will never see.
    Your description indicates to me that either the slab/foundation wall was not high enough above grade or that the grade has been raised over the years and created a problem.
