Thread: lucky pennies?
    Default lucky pennies?
    The flat roof I inspected today had quite a few pennies that looked deliberately placed. Is this some kind of lucky charm?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: lucky pennies?
    John: Could be, or Juan had a hole in his pocket.
    Were they all 'heads up'?
    Maybe checking the ... I have no idea ...
    Montreal, QC, Canada
    Maybe some form of anode to neutralize acid rain
    or
    Makeshift lighting arrestors
    or
    wear indicators - like built into rubber tires
    ......lol
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Were they all the same date? Possibly an indicator of when the roof was last coated.
    I've seen similar use of coins on window sills and door frames as part of a Chinese custom for good luck/keep away evil spirits etc. Feng Swei?
    877-466-8504
    Maybe its one of those pennies from heaven we've all heard about. I'm sure that kind of fall would create some heat on the coin and therefore make it stick in to the roof covering.
    Or maybe someone tossed it out the space station?
    rick
    Michael Farha's Avatar
    Michael Farha Guest
    They were most likely used to retard the growth of moss or fungus. Like running a copper wire across a comp roof to do the same thing. Moss and fungus usually grow on roofs where tree branches overhang and block the sun.
    South-West Michigan
    Post Re: lucky pennies?
    I have to go with the anti-fungal answer, sans Juan.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
