Results 1 to 3 of 3
    Eric Laney's Avatar
    Eric Laney Guest
    Default Weird wire attachment in FedPac
    Jumpers from one breaker to another appeared to be welded or even glued on. I hope someone has seen this and it is made that way. Comments needed.
    Default Re: Weird wire attachment in FedPac
    Eric,
    That's one version of a split bus panel.
    Did you treat that as service equipment, i.e., no more than 6 breakers to remove power, neutrals bonded to ground, etc.?
    I guess I should add ... not that it matters, it's an FPE after all ...
    Thus it needs to be replaced.
    Eric - The first time I saw one of those I wasn't sure what it was, until I posted the exact same question on this board.
