    Michael Vasquez's Avatar
    Michael Vasquez Guest
    Default New water heater installation
    In an existing house, when a new water heater is installed, should an in-sight or lockable disconnect also be installed if one was not available before?
    Default Re: New water heater installation
    It was a requirement for the original one and is still a requirement, so the answer is yes.
    Healdsburg, CA
    Refer 2008 NEC Article 422.47.
    Jerry McCarthy
    WC Jerry,
    You mean 422.31, right?
    Healdsburg, CA
    Yep. Haste makes waste and my memory ain't what it used to be and as my Doc says, "getting old is not for sissys."
    Jerry McCarthy
