Results 1 to 26 of 26
    Georgetown, KY
    Default What's missing in this chimney chase??
    No, I don't really need an answer!
    Default Re: What's missing in this chimney chase??
    Quote Originally Posted by Erby Crofutt View Post
    No, I don't really need an answer! -
    How about a question, then: How old was the house and had the fireplace ever been used?
    Georgetown, KY
    12 Years.
    Yes. A couple of times by current occupant (3 years).
    Unknown before that.
    Montreal, Quebec
    A house here under construction burnt down when one of the subs started a fire in the fireplace but did not realize the chimney was not finished being installed.
    Montreal, Quebec
    Jan 2009
    Tennessee
    Wink Re: What's missing in this chimney chase??
    I wonder if there is a statute of limitations on a stolen chimney?
    Barney
    Oct 2007
    Wichita, KS
    We've found that several times. Note the metal plate off to the side of the top of the fireplace. When we've found this, the plate was over the top of the chimney outlet on the appliance and they were going to put in vent free gas logs. They didn't realize that this is not an acceptable installation.
    Also missing is the header above the fp opening. Looks to be framed right down to the opening.
    Bart
    Quote Originally Posted by Bart Ogden View Post
    ...Also missing is the header above the fp opening. Looks to be framed right down to the opening...
    The fireplace IS the header! It's one of them there structural fireplaces!
    Question Re: What else is missing in this chimney chase??
    Bart, you got me looking closer!
    First of all, I don't see any plywood under the fireplace. It must be sitting on a solid continuous base. It appears someone forgot to frame out for this fireplace so they took a Sawzall and sliced through the studs so the box could slide in. The center stud is cut shorter to allow the starter collar to clear. The other studs do seem to be below those side spacers, which would be too close. Not having a header would make this wall wobble. If this is a load bearing wall there would need to be a load bearing header installed, preferrably at the top of the wall. If this is on an exterior wall, there would need to be insulation and sheathing inside the chase on the cold wall.
    Bart, that round disc could be a cut out where someone cut a hole in the subfloor above that extended into the chase as fireblocking. This is extremely common on the East coast. The installer cuts out for the listed firestop allowing the cutout to fall down, usually on top of the unit along with all the sawdust. If this is a cutout, the fact that it is not a square cut for a listed firestop but rather a round hole makes the whole installation a real abortion. Aside from installing the chimney, they really need to start from scratch and re-frame it with a base for the fireplace, insulation and sheathing in the chase such as Thermoply, fireblocking, listed firestops, etc. If that is blown insulation on top of the unit then you need to seal off the breach into the chase ( such as where you used to enter and get this view). This is also a huge energy hog being wide open.
    Let me guess---this passed inspection?
    Oct 2007
    Wichita, KS
    I thought about the fact it might be a cutout for above, but there's no plywood installed at the firestop location.
    If you look closely at the bottom of the picture, you can also see what appears to be a flexible gas appliance connector.
    This should be a poster child picture for what not to do......
    Bart
    The rounded disc may be where the roof sheathing was cut out for the chimney?
    Oct 2007
    Wichita, KS
    There indeed IS a chimney (chase), If there only WAS a flue........
    We've found those with a round piece of sheetmetal cut out and laid on top of the flue collar. "It's Vent Free......."
    Bart
    Are those walls supposed to insulted at some point or are they all interior?
    chuck altvater's Avatar
    chuck altvater Guest
    Even if they are all interior walls, they are de facto exterior walls since the chase is open to the attic. Not only should there be a chimney in there, unless there is a ventless gas log set, but the chase needs to be fireblocked as well.
    May 2007
    Tyler, TX
    I think y'all are all wrong. It's a recessed, big screen TV (that happens to be strong enough to hold up a wall).
    Bruce Thompson, Lic. #9199
    www.TylerHomeInspector.com
    Steve Olsen's Avatar
    Steve Olsen Guest
    Uh, the flue, the insulation on both side, the vapor barrier, a positive support to the vapor barrier and insulation (drywall, or maybe cement board if near the insert)
    Cleanup of the wood cuttings, fire hazard
    A closure to the attic, should be a fire rated wall.
    South-West Michigan
    Post Re: What's missing in this chimney chase??
    How about "everything."
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Matt Bezanson's Avatar
    Matt Bezanson Guest
    This brings up a question that has been bugging me for a while. On an interior chimney flue, assuming it's attached to a factory-built fireplace like that one above, is a fire-stop or fire-block required where the chase is open to the attic? And if so ( I have been assuming it's required) then where should the thermal insulation be?
    Matt
    Stacy, MN
    Quote Originally Posted by Matt Bezanson View Post
    Matt
    A fireblock is required at each floor level or at 10 foot max intervals and at the attic ceiling. If all the walls are interior the insulation would only need to be above the fireblock in the attic with a collar around the vent to maintain 1 inch of clearance from the vent to the insulation.
    Fuquay Varina, NC
    It's an old coal chute converted to cellulose pellet.
    I find it hard to believe that can occur. They are not allowed to sheath the wall until the fireplace and stack is in place and inspected.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Seeing is believing, as they say.
    Truth IS stranger than fiction at times.
    May 2010
    St. George, UT
    Finally someone has developed a fireplace to warm the whole house
    Quote Originally Posted by Larry Morrison View Post
    That will "quickly" warm the whole house.
    Fake fireplace..... what did I win???
    Georgetown, KY
    An old post kicking back to life for more learning!
    Phil Brody's Avatar
    Phil Brody Guest
    Or more humor, it's a DIRECT VENT !
