    Ron Bishop's Avatar
    Ron Bishop Guest
    Default unusual roofing material
    I ran across this roofing material today. It is an aluminum tile with a sprayed on granule similiar to what you would find on composition shingles. The material was so soft that i could hardly walk on it. The shingles were nailed in from the top without neoprene washers. Has anyone seen this material before??
    Default Re: unusual roofing material
    Quote Originally Posted by Ron Bishop View Post
    I ran across this roofing material today. It is an aluminum tile with a sprayed on granule similar to what you would find on composition shingles. The material was so soft that i could hardly walk on it. The shingles were nailed in from the top without neoprene washers. Has anyone seen this material before??
    I've seen it (or something similar) on a lot of commercial buildings.
    I've seen it installed once. It was several years ago, and I don't have the product info. any more (sorry). I wrote it up in the report that it looked like a poor design that would probably leak------I was told later on that the roof leaked soon thereafter.
    RB: They are steel, not aluminum.
    Gerard Roofing Technologies - Stone Coated Steel Roofs
    Granutile - a Stone Coated Metal Roofing Tile from ATAS International - Manufacturers of Metal Roofing, Walls, Ceilings, and Structural Components
    Stone Coated Steel Roofing - Stone Coated Metal Tile - Decra Roofing Systems
    Yeah did I say use a magnet? This one fooled me till I climbed back up with a magnet. They are indeed steel. Mine are nailed better than yours.
