    Darin Redding's Avatar
    Darin Redding Guest
    Default Ceiling ht. above water heater
    Hi guys. Quick question. I have a gas water heater in a small laundry area that has a low ceiling height. Understood the PRV drain is not to code, and there are other issues with this install but I'm curious about the low ceiling. Is there a minimum height required here?
    Thanks all for looking.
    Darin
    Default Re: Ceiling ht. above water heater
    The only minimum I can think of would be the minimum requirement of 5 feet for the minimum height of the vent.
    How high above the draft hood was the vent gas cap on the roof? At least 5 feet?
    Quote Originally Posted by Darin Redding View Post
    Darin
    States brand had 24" in their install guide from top to ceiling.
    Darin Redding Guest
    Gentlemen, Thanks for the quick reply. What a great resource this forum is.
    Jerry - the vent extends the required 5 feet above the roofing.
