    Austin
    Default Tiny Roofing Blisters?
    Hi,
    I could use a little help with this roof. It is 11 months old and installed on a new home in Texas. The roof decking has a radiant barrier and the large attic space has a continous hardie soffit vent and roof venting. I've seen larger blisters but this little round oozing bubble is about a 1/4 the size of a pea. Manufacturer's defect? Attic too hot?
    Thanks!
    Tampa, Fl
    Default Re: Tiny Roofing Blisters?
    My opinion is manufacturer's defect. Newer roof, so I would recommend a Manuf. Rep review and certify warranty.
    David Argabright's Avatar
    David Argabright Guest
    Possible hail damage?
    Shingle zit!
    I really don't see it as being an issue. Heck, I can barely see it at all.
    It does not look like hail, based on the hail damage I have seen. It could be residual moisture left over from the manufacturing process or who knows what.
    Dang, you got some good eyes!
    Austin
    Good eyes? No I tripped and fell on the roof and there it was. Serioiusly, these tiny bubbles are located on numerous shingles.
    Hail damage.....Yesterdays inspection
