Thread: Water intrusion
06-01-2007, 07:26 AM #1
Water intrusion
06-01-2007, 09:10 AM #2
Re: Water intrusion
After checking the area with a moisture meter and ensuring that it is dry NOW. I would look farther up the roof to determine where the moisture might have come from in the past. I looks to me that it might have been running down the 2x4 from higher up on the roof.
06-01-2007, 11:25 AM #3
Re: Water intrusion
John,
It's of course very common to find such stains but I for one don't recommend contractors come out solely based upon the presence of staining. My report will comment on the stain(s) found and leave it at that. Now of course I have raised a question in the client's mind (a good thing). Client will ask if there's a leak. I say "I have no idea - nothing's leaking right now, why not follow up with the seller? Perhaps get a response in writing and ask for receipts if repair has been made."
This approach has worked quite well. Raising questions causes the client to more likely do some followup on their own after the inspection because there isn't anyway that I'm going to have all the answers. If I can find reasons for my client to become more involved the better it is all the way around.
06-01-2007, 12:52 PM #4
Re: Water intrusion
Is that a gable wall with hardboard siding?
My approach is like Eric's.
06-01-2007, 07:07 PM #5
Re: Water intrusion
Also, remember, once stained, even if during construction, it will always be stained.
I put little faith in water stains on roof sheathing, gable end siding, wall sheathing were exposed to the interior, etc.. It just had to rain once during construction ... or any time since ... but my time machine broke a few years ago
so I cannot go back and find out just when the stain occurred and what the cause was.
Now, however, if it was wet when you were there ...
06-01-2007, 10:06 PM #6
06-24-2007, 04:41 PM #7
Re: Water intrusion
The overwhelming recommendation of seasoned inspectors and attorneys at continuing ed coferences seems to be to report what you see... as you've done. As with the others, I'd recommended following up with the seller. Are there problems outside? A patch or fresh paint inside?
06-25-2007, 08:29 AM #8
Re: Water intrusion
Those newer sections of underlayment appear recently installed. What is the material? Looks like cement board. Are the shingles new in this area? Were repairs already made?
06-25-2007, 08:30 AM #9
Re: Water intrusion
Is it possible that an attic fan was installed in this location in the past?
That would explain everything would't it?
