Results 1 to 4 of 4
    John Stephenson's Avatar
    John Stephenson Guest
    Default Window Glazing Trim
    Default Re: Window Glazing Trim
    The glass to frame seal on most metal windows is the flat surface of the inside of the glass which is adhered to the flat surface of the frame.
    That in the picture just looks like a buildup of crap over the years, maybe started out as overage of sealant. The plastic trim does nothing to seal against water, it is just a trim for glass retention and appearance.
    Richard Rushing's Avatar
    Richard Rushing Guest
    I believe that is called a glazing bead.
    RR
    Glazing bead - bingo!
    Buildup of crap - what's not to understand?
