Thread: TPR stand pipe material Help
06-04-2009, 11:15 AM #1
Can anyone tell me if this pvc is rated for use on a TPR?
Thanks,
Norm
06-04-2009, 11:25 AM #2
Re: TPR stand pipe material Help
Based on the ASTM rating (D2846) it seems to be CPVC not PVC.
06-04-2009, 11:42 AM #3
06-04-2009, 11:55 AM #4
06-04-2009, 12:15 PM #5
Sorry knew it was cpvc, but the 100 psi rating raised a question. When those blow 100 psi seems pretty low
Norm
06-04-2009, 12:17 PM #6
06-04-2009, 12:29 PM #7
DUH...................................... Thanks Matt. What's that saying ...... something about the forest and the trees
Norm
06-04-2009, 12:38 PM #8
No worries, I know I've done it a time or two. A common outcome when you like to shoot from the hip on an issue.
06-04-2009, 04:48 PM #9
Pipe OK
Solvent Cement OK
Fittings, Not OK
Fitting appears to be PVC if they were CPVC they would have the same coloration as the pipe.
Photo rotated and lightened.
06-04-2009, 04:49 PM #10
, yes, CPVC is allowed to be used for the T&P discharge line.
Good catch, I like it, sort of. Don't know where it's going to give a firm answer.
