		Thread: Flashed deck post
	06-26-2009, 10:15 AM #1 Flashed deck post Flashed deck postAnyone ever seen a deck guard post flashed like this?
 There is no actual decking on the roof, obviously, yet.
 Similar Threads:- Experts advise homeowners to give house a post-winter checkup - Ann Arbor News
- Porch Re-Roof - How Should This Be "Flashed"
- Where is the icon to post a donation for your efforts?
- Tip 3: Quicky View The Last Unread Post
- REAL ESTATE MAILBAG Is There Recourse With an Inspector Mishap? - Washington Post
	06-26-2009, 02:05 PM #2 Re: Flashed deck post Re: Flashed deck postCan't say I have seen one done like that. If they place any wood on that (looks like roll roofing) material it will puncture it in a short period of time.
 I would like to see that post isolated and not wrapped in anything.
 That will be a leaker down the road if it has not already started.
	06-26-2009, 02:08 PM #3 Re: Flashed deck post
		"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961) Re: Flashed deck post
	06-26-2009, 02:55 PM #4 Re: Flashed deck post Re: Flashed deck postLooks like modified to me, but, yes, it is flashed improperly.
 Let that wood shrink and crack and you will have water going down INSIDE the flashing, and the flashing will do a nice job of keeping the water inside the flashing and the roof covering, rotting out whatever it comes in contact with.
	06-26-2009, 04:24 PM #5 Re: Flashed deck post
	06-26-2009, 07:42 PM #6 Re: Flashed deck post Re: Flashed deck post
	06-27-2009, 03:20 AM #7 Re: Flashed deck post Re: Flashed deck postAs a possible improvement to BB's graphic I would insist upon the top of the flashing being installed in a kerf cut around the perimter of the post.
  Reply With Quote Originally Posted by Scott Patterson
