Thread: Exterior stairs
    Default Exterior stairs
    Any possible exceptions to the 36" minimum stair width here?
    Even if there are two of them?
    Default Re: Exterior stairs
    Yes, ... they can be wider ...
    (I know, you said 'minimum' too.)
    Carrolton inspection
    These stairs on the outside could only be made wider by cutting into the garage door opening as well as the stairs in side. Or tearing the house apart to have an inset for the stairs
    Call it a diving platform, different rules for those.
    Not a problem ... does not meet those EITHER.
    Jim,
    I guess the paramedics could drag the body to the other end of the pool to pull it out of the water. Those stairs appear to block the access on the pool deck for the stretcher to place the body on.
    Oh well.
