07-06-2009, 03:14 PM #1
How many of you see premature water heater leaks ?
How many of you see premature water heater leaks ? meaning a leaking water heater that is fairly new (5 years or less). I am referring to a tank leak, not a plumbing connection leak. I have see two in the past 300 or so inspections. Just wondered what others see, what generally what percentage thereabouts of early failures?
07-06-2009, 05:26 PM #2
Re: How many of you see premature water heater leaks ?
I average about 10 water heaters a year with leaking tanks that where still within the 6 year tank warranty. In most cases they fail due to mishandling, and the inner lining gets cracked. Also some units might have had the anode rods removed due to the rotten egg smell, which will shorten the life of the tank.
Ron Hasil IL Plumbing Lic #058-160417
A-Archer Sewer & Plumbing specializing in:
Tankless Water Heaters | Drain and Sewer Cleaning | Sump and Ejector Pumps | Backflow RPZ Testing
07-06-2009, 07:42 PM #3
As a plumber, none that I've installed have started leaking prematurely. *crosses fingers*
However, that doesn't include manufacturing defects that I noticed as soon as I filled the tank: cracked bungs, thermostats cross-threaded, etc.
07-06-2009, 07:56 PM #4
07-06-2009, 08:04 PM #5
Have manufacturers started making these tanks with thinner steel walls? I had heard this recently. The thinner walls will make the tanks leak quicker, tanks will only last 4-5 years. Anyone hear of this?
07-06-2009, 08:06 PM #6
07-06-2009, 09:03 PM #7
NACHI produced an educational video about tankless water heaters.
The featured plumber/installer said, "in order to conform to govt. mandated efficiency enhancement; manufacturers are using thinner gauge steel to improve heat transfer."
The plumber makes a living installing $2,500 tankless units but he may be factual.
Anecdotal thought: I use four cast iron skillets for cooking and several copper bottomed (Revere Ware) and Aluminum skillets and though I think the initial heat transfer rate varies I don't think therms are wasted. ( maybee this will start a cooking thread )
07-11-2009, 08:48 PM #8
