Results 1 to 20 of 20
Thread: 234 on 789
    Bud Butczynski's Avatar
    Bud Butczynski Guest
    Default 234 on 789
    How do you spell fire?
    Attached Files Attached Files
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: 234 on 789
    You need an Infrared Camera to help with that image.
    Best
    Ron
    Apr 2009
    NY State
    Hello Mr. Zinsco.
    Hopefully the panel cover is intact and in place so there will be no fire if that thing decides to burn up.
    Best
    Ron
    No he doesn't, he needs to recommend replacing that panel as it is a Zinsco.
    Know where there is no breaker in the spot above that breaker? Look at the burned bus bar (the spot on the left bus bar).
    That breaker (the hot one) has most likely welded itself to the bus bar.
    I was thinking the same thing, Jerry. Fred Flintstone could have captured this problem with a sharp beaked bird and a piece of bedrock. Not only was it fused to the panel, but the "toggle" for lack of a better term was neither in the tripped or engaged position (slid from left to right and back again without performing any function).
    South-West Michigan
    Post Re: 234 on 789
    Excellent catch, Bud!
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    High Point, NC
    Will someone please tell me the significance of "789"?
    In addition, I am unable to discern that the toggle on the top breaker in the photo has moved from its "far left" position.
    Secondly, I do see the small dark spot on the buss bar in the open space of the panel and I see a darkened or shadowed spot on the top side of the top breaker where it wraps the right side buss bar. I can assume that it is evidence of overheating. Is there additional evidence that I am missing?
    Quote Originally Posted by Tom Edwards View Post
    That would be breakers 7, 8, and 9.
    Possibly experience with Zinsco panels?
    If you've ever seen one, you will understand what the problem is and why.
    Or perhaps 07/08/09 as in the date on the photo.
    Apr 2009
    NY State
    Did anyone look at the clock at 12:34 & 56 sec on 7/8/09?
    That made it 123456789. If not try again in 100 years.
    There was a 9/8/07 6:54:32:10 making it 9876543210
    Apr 2009
    NY State
    Yup. That too.
    On The Mason-Dixon Line
    I prefer the even number so I'm waiting till August of next year
    2:46 on 8/10 - 2 4 6 8 10
    High Point, NC
    Thanks.
    I wasn't aware of how 7, 8 & 9 fit in this example. Silly me! However, with the help of more experienced HI's and electrical contractors in my family, I've become quite aware of Zinsco-type panels. I think I am one of the few in my market area that call them out correctly for the benefit of my client and have done so for at least 10 years. And no, agents don't like me much for doing so.
    Before I began home inspectors full time, only 20 years ago, I served as a code inspector. I'm still learning.
    I am wondering if I can hit the lotto using 090909 this September ninth.
    25 or 6 to 4 at least in Chicago.
    789 simply reflects the date.
    "Now if uh, six........
    turned out to be nine........
    I dont mind, I dont mind"
    Tom,
    Looks like that 789 reference was the date according to the original poster in an updated message.
    Most panels, as you are aware, number one of two ways:
    - down and across, i.e., top left is one, top right is two, second down on top left is three, etc.
    - down the left side and then down the right side
    Zinsco breakers only have one row of breakers going down, so their numbers start and the top and go 1, 2, 3, etc., which I presumed meant that 789 was breakers 7, 8, and 9. Silly me, it was the date.
    Quote Originally Posted by Bud Butczynski View Post
    YouTube - Easy Rider - Jimi Hendrix - If 6 Was 9
    High Point, NC
    Thanks, Bud.
    Glad I asked the question.
    I thought your original post seemed a bit mysterious with reference to "789". I could not figure how a high temp reading on a single breaker was referencing "breakers 7, 8 & 9". You've cleared it up.
