    May 2007
    Tyler, TX
    Default Unknown items in electrical cabinet
    I know I've not been around the block as some of you (that's a compliment)
    These items were installed in the bottom of the cabinet; they were wired in. "Motorola" was imprinted on the side.
    I'd appreciate any help.
    Bruce
    Bruce Thompson, Lic. #9199
    www.TylerHomeInspector.com
    Default Re: Unknown items in electrical cabinet
    I think they are surge protectors.
    Yes, surge protectors and they should be mounted through the exterior of the cabinet, *not* "in" the cabinet as you see them.
    Also see a lot of multiple tapped neutrals.
    Mar 2009
    Colorado Front Range
    Wink Re: Unknown items in electrical cabinet
    You DID pick up on the fact this is a FPE panel, right?
    May 2007
    Tyler, TX
    Yep, gave them my standard FP line and recommended a new panel...hopefully taking care of the doubled-neutrals and the surge-protectors mounted in the cabinet
    Thanks for all of the help. I appreciate you guys.
    Bruce
    Good to see that dirty old US FPE panel is surge protected.
    The neutral bus appears to be bonded to a ground on the right with several white wires.
    Amateur workmanship?
    A.D. Miller's Avatar
    A.D. Miller Guest
    JP: But, they are so symmetrically wrong.
    Todd Johnson's Avatar
    Todd Johnson Guest
    I dont know guys,,,is that the buss they are connected to or the mounting screws to the back plate? In all my years I dont think I have seen one quite like this. I give JB an A+ for uniqueness!
    Quote Originally Posted by Todd Johnson View Post
    Looks like the bus bar connections where the breaker mounts are bolted to the bus bars.
    Todd Johnson Guest
    Well...now that I have cleaned my bifocals I think JP is right again!
