Results 1 to 11 of 11
    Brian Burns's Avatar
    Brian Burns Guest
    Question AFCI and GFCI Question
    I did a new construction home today and came across this issue.
    The breaker panel has 2 seperate circuits for the bedrooms and they are AFCI protected.
    These circuits also feed the master bathroom and the hallway bathroom.
    The bathrooms are GFCI protected.
    My question is should the GFCI outlets in the bathrooms be fed from an AFCI protected outlet or should they be on thier own circuits?
    Thank for your help!
    Brian Burns
    MHHI
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: AFCI and GFCI Question
    Bathrooms should be on their own circuit.
    RR
    RR
    Which should be GFCI protected.
    Si...
    RR
    Brian Burns Guest
    I thought so,
    Thanks alot!!!
    Brian
    Corpus Christi, TX
    Brian,
    Thought you might find interesting.
    Siemens Introduces Combination ARC Fault Circuit Interrupters
    - Paul Fix
    Yeah... thank's Gerry
    RR
    Quote Originally Posted by Thom Walker View Post
    Brian,
    But ...
    They are not "combination AFCI and GFCI", only combinations of types of AFCI to protect against various types of arcs.
    Corpus Christi, TX
    That is correct.
    What I found interesting was that with this one detecting arcs at loose connection it seems to have implications for Al conductors. I haven't seen any testing data yet. Wonder if any mfrs have thought about it?
    This is major drift. Sorry, Brian
    - Paul Fix
    David Banks's Avatar
    David Banks Guest
    Richard I mean Rodney how does it feel under the Bus? I mean I get no respect!
    Ft. Lauderdale Fl
    That is correct.
    I think I asked Doug when this first came out as to a solution for AL wiring. He gave me a long explanation, bottom lime will not work.
    Captain
