    Default Can this really happen?
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Can this really happen?
    Quote Originally Posted by Reis Pearson View Post
    It seems to me that this might be a bad idea? Any insight?
    RP: It may be a good idea if, for example, you place a BBQ unit here. You have gas for the burners and electricity for the rotisserie.
    Jack Murdock's Avatar
    Jack Murdock Guest
    Reis,
    As it stands that csst is terminated properly and left gas-tight. (assuming its bonded inside per the man instructions etc) The only issue would be if a source of ignition is plugged into that outlet and there is a gas meter with a regulator or an LP regulator within 5 feet of the source of ignition. Is that the service entrance or an exit for a gas grill or ?
    Jack
    Okay, this was a DUMB question and I realized after I posted. Yes, it is a gas stub for a gas grill and the proper bonding at the interior has been done. I went on the ignition source train without fully thinking it through... Sorry to waste anyone's time.
    Thanks for your replies!
    A.D. Miller Guest
    RP: Those sorts of mental episodes are experienced by everyone.
    Michael Larson's Avatar
    Michael Larson Guest
    For some more than others.
