Results 1 to 11 of 11
    wes owens's Avatar
    wes owens Guest
    Default discolored cpvc on water heater
    Anyone ever see cpvc stain like this, and why?
    This is from the TPR valve on a gas water heater.
    And yes, it had other issues like being too close to the washing machine, cpcv on the supplies too close to vent pipe, vent pipe too close to ceiling combustibles, no seismic straps, and no drip pan to name a few.
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: discolored cpvc on water heater
    I've got one better than that from my inspection today...
    Wes,
    I'm guessing that's from 'mist' from the clothes washer right next to it.
    Richard Stanley's Avatar
    Richard Stanley Guest
    Nicotine!!
    wes owens's Avatar
    wes owens Guest
    Will soap stain CPVC?
    Or it might be bleach.
    I hadn't thought of that.
    Myrtle Beach, South Carolina
    I'm going with Nicotine. Have seen that in homes with smokers.
    www.Home2Spec.com
    Mike Cudahy's Avatar
    Mike Cudahy Guest
    I'm going with either a combination of cleaning products from the washing machine falling out on the pipe, or someone did the good old Rit tie-dye powder trick in the machine.
    Corpus Christi, TX
    Nicotine!!
    Oh yeah, Mr. Goody-two-shoes. Like you never used your water heater for a bong.
    Wes, did it rub off?
    - Paul Fix
    What's a bong?????
    wes owens's Avatar
    wes owens Guest
    It did not rub off and was only on the one pipe.
    James Duffin's Avatar
    James Duffin Guest
    You must have had a party to need a WH for a bong....interetesting idea though!
