    John Stephenson's Avatar
    John Stephenson Guest
    Default A+ for effort, but is it allowed?
    Chip O'Brian's Avatar
    Chip O'Brian Guest
    Default Re: A+ for effort, but is it allowed?
    Is this a new build? if so hire a new contractor. As to the flashing it appears to be a poor attempt at a diverter/kickout flashing. At any rate incorrect this would create moisture issues runnning water down the sidding.
    As to the boots looks like a home style fix to me!
    Chad Fabry's Avatar
    Chad Fabry Guest
    That's just hokie.
    Apr 2007
    gainesville fl
    Was there a kickout flashing?
    South-West Michigan
    Post Re: A+ for effort, but is it allowed?
    No-go.
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    'D' for Dumb. Why worry whether or not it is 'allowed' when a little bit of thinking will tell you that it won't perform? The bottom lip of the boot will not drain and will actually collect moisture. Even if he drilled or cut a weep hole in the bottom of the boot, the flexible flashing is prone to excess motion and sealant failure. Corporate specs? Like Enron, Kerr McGee, Halliburton, etc? Your BS detector should be in the red zone.
    Dan Cullen
    www.domicileconsulting.com
